简介
Durst Enlargers and the negative carriers have been ubiquitous back in the age of film photography. They still are great products, but replacements have been hard to come by. I will show how I replaced the glass inserts of my Sireneg negative holder without any special tools. Sadly I didn't document the process in detail, so I can only describe the necessary steps.
Sourcing
Material sourcing is the most important step for this replacement.
The ideal suppliers for the needed specialty glasses are local artwork-framing businesses. You should get precut pieces of glass so you don't have to cut and grind them.
你所需要的
Dissemble the negative carrier by unscrewing it at the hinge
Select one part of the negative carrier to work on. Store the other one in a secure location
The image of the lower half of the carrier shows the already replaced glasses. I'll try to supply better photos for documentation
Hold one half of the negative carrier in you non-dominant hand
With the other hand firmly grab the glass from both sides
Slightly push the glass towards to sheet metal flap on the side of the negative carrier hinge
Allow the glass to tilt upwards at the side opposite to the hinge
Repeat for the second half of the negative carrier
Use a ruler to measure glasses
Note that the glasses are beveled along the long edges. This is how the are secured in the negative holder
Take the following measurements:
Total size of the glasses. In my case: 75 x 65 mm
Size of the glasses without the bevels. In my case: 75 x 60 mm
Procure the needed glases
If you can get beveled glasses, get the measured total size
If you can only get even edges, get the smaller measured size
You can also cut the glasses from a bigger sheet of glass.
Instructions can be found here
Grinding glass is a dangerous and tedious business. Use an alternative material to add the bevels to the glass
I have used a precut matte for framing photographs and artwork
Use material with lesser thickness than the used glasses
Add a 45° bevel to the edge of your material. In case of a matte use the prepared edges of the cutout
Cut a small strip of material that includes the bevel. Choose the with of the strip appropriately to match the total size of the glasses when you add to of the strips to the long edges
Cut a strip of double sided adhesive tape that matches the glass thickness
Apply the adhesive to the long edges of the glas
Remove the securing layer of the adhesive tape
Firmly press one of your bevel strips to the glued edge to join the parts
You can see the glued bevels at the top and bottom of the glass in the picture
Slide the top edge of the glass under the metal spring on the negative carier
Make sure not to indent the bevel material if you have choosen a soft alternative like matte board
Slide the bottom bevel under the holders on the bottom side of the negative carrier
