跳转到主内容
Minolta QTsi Maxxum Shutter Button Replacement
你所需要的
  1. Minolta QTsi Maxxum Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 1,1
    • Locate the battery compartment on the bottom panel of the camera.
    • Open the battery door by using a coin.
    • In the counterclockwise direction, twist the coin in the battery door groove to open it.
  2. Minolta QTsi Maxxum Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Two batteries are located inside the battery chamber.
    • Remove the two batteries from the battery chamber by picking them up.
  3. Minolta QTsi Maxxum Shutter Button Replacement: 步骤 3 中的图像 1,1
    • There is a screw located underneath the batteries in the battery compartment.
    • Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
    • Ensure good lighting before attempting to remove this screw because it is hard to see inside the compartment.
  4. Minolta QTsi Maxxum Shutter Button Replacement: 步骤 4 中的图像 1,1
    • From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
    • Be careful because you can lose the screw
  5. Minolta QTsi Maxxum Shutter Button Replacement: 步骤 5 中的图像 1,1
    • The only screws remaining that hold the top panel of the camera in place are located next to the view finder.
    • Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
  6. Minolta QTsi Maxxum Shutter Button Replacement: 步骤 6 中的图像 1,2 Minolta QTsi Maxxum Shutter Button Replacement: 步骤 6 中的图像 2,2
    • The top panel of the camera should now be easy to lift off. If it is not, make sure that all screws and attachments, listed in steps 1-5, have been removed.
    • Once all screws are removed, lift the top panel from the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  7. Minolta QTsi Maxxum Shutter Button Replacement: 步骤 7 中的图像 1,1
    • Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
结论
另外一个人完成了本指南。
Jordan Ellery
于10/10/16注册
388 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 484
