跳转到主内容
Minolta QTsi Maxxum Lens Replacement
你所需要的
  1. Minolta QTsi Maxxum Lens Replacement, Lens: 步骤 1 中的图像 1,2 Minolta QTsi Maxxum Lens Replacement, Lens: 步骤 1 中的图像 2,2
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: 步骤 2 中的图像 1,1
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: 步骤 3 中的图像 1,2 Minolta QTsi Maxxum Lens Replacement: 步骤 3 中的图像 2,2
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
结论
Jordan Ellery
于10/10/16注册
388 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 16
总计 591
