简介
Having trouble selecting camera functions? Top dial a little sticky or damaged? This guide will instruct you on how to remove and replace it.
配件
没有特定配件。
Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
Remove the two silver Phillips #00 2.5 mm screws attached to the bottom of the dial on the inside of the top panel.
另外一个人完成了本指南。
