跳转到主内容
Minolta Maxxum QTSI Tripod Mount Replacement
你所需要的
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: 步骤 1 中的图像 1,1
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: 步骤 2 中的图像 1,2 Minolta Maxxum QTSI Tripod Mount Replacement: 步骤 2 中的图像 2,2
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: 步骤 3 中的图像 1,1
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: 步骤 4 中的图像 1,2 Minolta Maxxum QTSI Tripod Mount Replacement: 步骤 4 中的图像 2,2
    • Use the tweezers to gently remove the tripod socket, and replace it.
结论
Jordan Ellery
于10/10/16注册
388 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 358
