跳转到主内容
Minolta Dimage Xt LCD Screen Disassembly
你所需要的
  1. Minolta Dimage Xt LCD Screen Disassembly, Casing: 步骤 1 中的图像 1,3 Minolta Dimage Xt LCD Screen Disassembly, Casing: 步骤 1 中的图像 2,3 Minolta Dimage Xt LCD Screen Disassembly, Casing: 步骤 1 中的图像 3,3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt LCD Screen Disassembly: 步骤 2 中的图像 1,3 Minolta Dimage Xt LCD Screen Disassembly: 步骤 2 中的图像 2,3 Minolta Dimage Xt LCD Screen Disassembly: 步骤 2 中的图像 3,3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt LCD Screen Disassembly, LCD Screen: 步骤 3 中的图像 1,1
    • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
    • The screen also has a ribbon wire connected at the bottom of the screen.
  4. Minolta Dimage Xt LCD Screen Disassembly: 步骤 4 中的图像 1,2 Minolta Dimage Xt LCD Screen Disassembly: 步骤 4 中的图像 2,2
    • Detach the connector at the bottom from the LCD screen.
    • Starting from the side or a corner gently slide the spudger underneath the screen.
    • Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
  5. Minolta Dimage Xt LCD Screen Disassembly: 步骤 5 中的图像 1,1
    • The screen is not detached. Wires are still connecting the screen to the camera at the bottom corners, but it is removed from the bracket.
    • Check to make sure the wires are connected, so it will receive proper power supply.
    • To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
结论
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
另外一个人完成了本指南。
Keith Sechrist
于03/11/13注册
22 声望
创作了2篇指南
团队
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G4
3 名成员
创作了14篇指南
一条评论
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 974
