跳转到主内容
Minolta Dimage Xt Flashbulb and Housing Replacement
你所需要的
  1. Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: 步骤 1 中的图像 1,3 Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: 步骤 1 中的图像 2,3 Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: 步骤 1 中的图像 3,3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flashbulb and Housing Replacement: 步骤 2 中的图像 1,3 Minolta Dimage Xt Flashbulb and Housing Replacement: 步骤 2 中的图像 2,3 Minolta Dimage Xt Flashbulb and Housing Replacement: 步骤 2 中的图像 3,3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flashbulb and Housing Replacement, Flashbulb and Housing: 步骤 3 中的图像 1,2 Minolta Dimage Xt Flashbulb and Housing Replacement, Flashbulb and Housing: 步骤 3 中的图像 2,2
    • Remove 2mm screws connecting the flash housing to the main components of the camera.
    • Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
  4. Minolta Dimage Xt Flashbulb and Housing Replacement: 步骤 4 中的图像 1,3 Minolta Dimage Xt Flashbulb and Housing Replacement: 步骤 4 中的图像 2,3 Minolta Dimage Xt Flashbulb and Housing Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
    • Once the screws have been removed, pull the circuit board away from the body of the camera.
    • Wires will keep it from completely detaching.
    • Pull the housing away from the circuit board.
结论
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
Keith Sechrist
于03/11/13注册
22 声望
创作了2篇指南
团队
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 551
