跳转到主内容
Minolta Dimage Xt Flash Capacitor Replacement
你所需要的
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: 步骤 1 中的图像 1,3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: 步骤 1 中的图像 2,3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: 步骤 1 中的图像 3,3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: 步骤 2 中的图像 1,3 Minolta Dimage Xt Flash Capacitor Replacement: 步骤 2 中的图像 2,3 Minolta Dimage Xt Flash Capacitor Replacement: 步骤 2 中的图像 3,3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: 步骤 3 中的图像 1,2 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: 步骤 3 中的图像 2,2
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
结论
另外一个人完成了本指南。
Qqq
于03/11/13注册
19 声望
撰写一个指南
一条评论
Its a cap not a battery :D
Eigirdas Gedgaudas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,035
