跳转到主内容
Minolta Dimage Xt Capture Button Replacement
你所需要的
  1. Minolta Dimage Xt Capture Button Replacement, Casing: 步骤 1 中的图像 1,3 Minolta Dimage Xt Capture Button Replacement, Casing: 步骤 1 中的图像 2,3 Minolta Dimage Xt Capture Button Replacement, Casing: 步骤 1 中的图像 3,3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Capture Button Replacement: 步骤 2 中的图像 1,3 Minolta Dimage Xt Capture Button Replacement: 步骤 2 中的图像 2,3 Minolta Dimage Xt Capture Button Replacement: 步骤 2 中的图像 3,3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: 步骤 3 中的图像 1,1
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  4. Minolta Dimage Xt Capture Button Replacement: 步骤 4 中的图像 1,1
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
结论
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
于03/11/13注册
28 声望
创作了5篇指南
团队
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 438
