当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Clean the propeller and surrounding area so that you’re working with clean materials. This can also help loosen bolts, and make it easier to take apart.
Make sure that the trolling motor is disconnected from any power source.
Remove the locking nut by turning in a counterclockwise motion.
Once you've unscrewed the propeller nut, you must also remove the lock washer located directly beneath.
If you purchased a new propeller kit, you may replace the old lock washer with the new washer you received in your kit.
Remove the drive pin by pushing on either side so it slides out.
When reinstalling your new propeller, make sure to properly align the drive pin with the base of the new propeller.
取消:我没有完成这个指南。
2等其他人完成本指南。
与1其他贡献者
于02/22/18注册
175 声望
撰写一个指南
徽章: 5
+ 2更多徽章
UM-BADDOUR-S18S4G9
2 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 47
总计 5,457
