跳转到主内容
Minn Kota Trolling Motor Propeller Replacement
你所需要的
  1. Minn Kota Trolling Motor Propeller Replacement, Propeller: 步骤 1 中的图像 1,1
    • Clean the propeller and surrounding area so that you’re working with clean materials. This can also help loosen bolts, and make it easier to take apart.
    • Make sure that the trolling motor is disconnected from any power source.
  2. Minn Kota Trolling Motor Propeller Replacement: 步骤 2 中的图像 1,2 Minn Kota Trolling Motor Propeller Replacement: 步骤 2 中的图像 2,2
    • Remove the locking nut by turning in a counterclockwise motion.
  3. Minn Kota Trolling Motor Propeller Replacement: 步骤 3 中的图像 1,2 Minn Kota Trolling Motor Propeller Replacement: 步骤 3 中的图像 2,2
    • Once you've unscrewed the propeller nut, you must also remove the lock washer located directly beneath.
    • If you purchased a new propeller kit, you may replace the old lock washer with the new washer you received in your kit.
  4. Minn Kota Trolling Motor Propeller Replacement: 步骤 4 中的图像 1,3 Minn Kota Trolling Motor Propeller Replacement: 步骤 4 中的图像 2,3 Minn Kota Trolling Motor Propeller Replacement: 步骤 4 中的图像 3,3
    • Remove the drive pin by pushing on either side so it slides out.
  5. Minn Kota Trolling Motor Propeller Replacement: 步骤 5 中的图像 1,1
    • When reinstalling your new propeller, make sure to properly align the drive pin with the base of the new propeller.
结论
Once you have the drive pin lined up correctly with the base of the propeller, repeat steps 1-3 in reverse order. Make sure to utilize your new parts such as the drive pin and lock washer if you purchased a propeller replacement kit to replace your old hardware.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 48
总计 5,457
