简介
If you need to replace the motor on your Milwaukee M18 cordless power drill (Model # 2606-20) see this guide on how to remove it. The motor is the powerhouse of the drill allowing it to complete its job. Replacing the motor may be necessary if the motor is making noise or losing speed during operation. Remember to be careful when removing items from the drill to avoid having to replace other items.
你所需要的
Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
2等其他人完成本指南。
