当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
Rotate the screw clockwise to loosen it.
The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
The Allen wrench will be used for leverage when removing the chuck.
When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
