跳转到主内容
Milwaukee M18 2606-20 Gearbox Replacement
你所需要的
  1. Milwaukee M18 2606-20 Gearbox Replacement, Chuck: 步骤 1 中的图像 1,3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: 步骤 1 中的图像 2,3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: 步骤 1 中的图像 3,3
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 2 中的图像 1,2 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 2 中的图像 2,2
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 3 中的图像 1,2 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 3 中的图像 2,2
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 4 中的图像 1,3 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 4 中的图像 2,3 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 4 中的图像 3,3
    • Rotate the Allen wrench counterclockwise to remove the chuck.
  5. Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: 步骤 5 中的图像 1,2 Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: 步骤 5 中的图像 2,2
    • Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
    • Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
  6. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 6 中的图像 1,3 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 6 中的图像 2,3 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 6 中的图像 3,3
    • Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
  7. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 7 中的图像 1,2 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 7 中的图像 2,2
    • Peel back the sticker at the bottom of the drill handle.
  8. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 8 中的图像 1,2 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 8 中的图像 2,2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  9. Milwaukee M18 2606-20 Gearbox Replacement: 步骤 9 中的图像 1,2 Milwaukee M18 2606-20 Gearbox Replacement: 步骤 9 中的图像 2,2
    • Lift the gearbox slightly and pull away from the motor to remove it from the case .
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 74
总计 3,726
