跳转到主内容
Milwaukee M18 2606-20 Chuck Replacement
你所需要的
  1. Milwaukee M18 2606-20 Chuck Replacement, Chuck: 步骤 1 中的图像 1,3 Milwaukee M18 2606-20 Chuck Replacement, Chuck: 步骤 1 中的图像 2,3 Milwaukee M18 2606-20 Chuck Replacement, Chuck: 步骤 1 中的图像 3,3
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Chuck Replacement: 步骤 2 中的图像 1,2 Milwaukee M18 2606-20 Chuck Replacement: 步骤 2 中的图像 2,2
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Chuck Replacement: 步骤 3 中的图像 1,2 Milwaukee M18 2606-20 Chuck Replacement: 步骤 3 中的图像 2,2
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Chuck Replacement: 步骤 4 中的图像 1,3 Milwaukee M18 2606-20 Chuck Replacement: 步骤 4 中的图像 2,3 Milwaukee M18 2606-20 Chuck Replacement: 步骤 4 中的图像 3,3
    • Rotate the Allen wrench counterclockwise to remove the chuck.
结论
2等其他人完成本指南。
4条评论
Milwaukee say to heat the tort screw up to loosen the locktite. Did this to the second chuck I replaced came off much easier. Getting the chuck off was a different story, tried hitting a 10mm allan key in the chuck didn’t work. Ended up getting a 10mm 1/2’ allan head socket on a breaker bar. Put the drill on the ground stood on it and with the other leg kicked the breaker bar. Came straight off.
tim.karen.collins - 回复
My chuck was stuck and working rough, needed to get it off the drill motor. Worked on a Harbor Freight Hercules 1/2” hammer/drill just fine. Neat trick using the Allen for leverage! Looks a lot like a copy…
Thanks! Dave D.
David Dryden - 回复
Not really clear in what mode it needs to be, nor what rotation mode
Rombout Versluijs - 回复
1st gear and twist the drill threshold to the drill bit setting (max torque).
Dustin Gordon -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 177
总计 18,504
