跳转到主内容
Milwaukee M12 2407-20 Speed Selector Lever Replacement
你所需要的
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: 步骤 2 中的图像 1,1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: 步骤 3 中的图像 1,3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: 步骤 3 中的图像 2,3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: 步骤 3 中的图像 3,3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to pry the broken speed selector lever off the assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,602
