跳转到主内容
Milwaukee M12 2407-20 Shuttle Spring Plate Replacement
你所需要的
  1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: 步骤 2 中的图像 1,1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: 步骤 3 中的图像 1,3 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: 步骤 3 中的图像 2,3 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: 步骤 3 中的图像 3,3
    • Use both hands to lift and remove the gear case assembly from the shell casing.
    • Set the gear case assembly aside.
  4. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: 步骤 4 中的图像 1,2 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: 步骤 4 中的图像 2,2
    • Remove the forward/reversing shuttle to gain access to the spring plate.
  5. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: 步骤 5 中的图像 1,1
    • Remove the spring plate and insert replacement spring plate.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 34
总计 1,290
