跳转到主内容
Milwaukee M12 2407-20 Outer Casing Replacement
你所需要的
  1. Milwaukee M12 2407-20 Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Outer Casing Replacement: 步骤 2 中的图像 1,1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
终点
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 3,211
