跳转到主内容
Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement
你所需要的
  1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: 步骤 1 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: 步骤 1 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: 步骤 1 中的图像 3,3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device, making the gray part face to the right.
    • Remove four 14mm screws using a T20 Torx screwdriver.
    • Remove four 18mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 2 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 2 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 2 中的图像 3,3
    • Hold the device so the gearbox assembly faces directly towards you.
    • Remove the four screws using a T20 Torx screwdriver.
    • Using a plastic opening tool, pry the gearbox assembly away from the clam shell.
  3. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 3 中的图像 1,1
    • After all necessary screws are removed, gently remove the upper red cover from the device.
    • Remove the gray motor and gearbox assembly.
    • Remove the gearbox gently as to not damage the brushes.
  4. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 4 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 4 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 步骤 4 中的图像 3,3
    • Attach a bearing removal tool to the bearing.
    • Tighten the bearing puller until the bearing comes off of the motor shaft.
    • For easier removal, lightly heat the bearing with a propane torch.
    • Heat and then press the replacement bearing onto the shaft.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 590
