跳转到主内容
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
你所需要的
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: 步骤 1 中的图像 3,3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 2 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 2 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 2 中的图像 3,3
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 3 中的图像 1,2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 3 中的图像 2,2
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 4 中的图像 1,2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 4 中的图像 2,2
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 5 中的图像 1,2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 步骤 5 中的图像 2,2
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 364
