跳转到主内容
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
你所需要的
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 步骤 1 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 步骤 1 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 步骤 1 中的图像 3,3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 2 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 2 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 2 中的图像 3,3
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 3 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 3 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 3 中的图像 3,3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 4 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 4 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 4 中的图像 3,3
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 步骤 5 中的图像 1,1
    • Pull straight up on the field winding to remove it from the body.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 360
