简介
Keeping clean motor brushes is a vital way to ensure the device is working well. If you are hearing a rough sound when using the device, it might be a time to replace the motor brushes. If the brushes are too worn the tool may not function at all.
If the motor brushes are dirty or are in need of replacement, use this guide to replace the motor brush in your device.
你所需要的
Flip the device and remove (6) 5 x 18mm screws with a T-20 screwdriver.
Remove (4) 5 x 14mm screws. with T-20 screwdriver.
即将完成!
结论
