跳转到主内容
Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement
你所需要的
  1. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 步骤 1 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 步骤 1 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 步骤 1 中的图像 3,3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove (6) 5 x 18mm screws with a T-20 screwdriver.
    • Remove (4) 5 x 14mm screws. with T-20 screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 2 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 2 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 2 中的图像 3,3
    • Hold the device so the gray gearbox assembly faces directly towards you.
    • Remove the four screws with a T-20 screwdriver.
    • After removing all screws, use a small plastic opening tool to slide the gearbox assembly forward.
  3. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 3 中的图像 1,3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 3 中的图像 2,3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 3 中的图像 3,3
    • Gently remove the upper clam shell.
    • Slide the motor and gearbox assembly out the front of the device and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The brushes may need to be compressed in order for the motor to be removed.
  4. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 4 中的图像 1,2 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 步骤 4 中的图像 2,2
    • Remove the brushes from the mount by pulling the brush body directly upward.
    • Disconnect the blue wire from the lower brush.
    • Disconnect the white wire from the upper brush.
    • Reconnect the wires to the new brush and replace them back into the mount.
    • The brushes may need to be compressed in order to slide the motor back into position.
结论
一条评论
Wear to find brushes for impact
Laurie Hathaway-Ashby - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 635
