跳转到主内容
Milwaukee Hole Hawg 1675-1 Field Replacement
你所需要的
  1. Milwaukee Hole Hawg 1675-1 Field Replacement, Motor Brushes: 步骤 1 中的图像 1,1
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 2 中的图像 1,3 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 2 中的图像 2,3 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 2 中的图像 3,3
    • Remove the brush cap with a flathead screwdriver.
  3. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 3 中的图像 1,2 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 3 中的图像 2,2
    • Pry up on the copper brush holder with a screwdriver or spudger.
    • Continue lifting up the copper brush holder to remove the brush.
    • Repeat on the opposite side.
  4. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: 步骤 4 中的图像 1,2 Milwaukee Hole Hawg 1675-1 Field Replacement, Field: 步骤 4 中的图像 2,2
    • Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
  5. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 5 中的图像 1,3 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 5 中的图像 2,3 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 5 中的图像 3,3
    • Remove the motor cover and withdraw the armature.
    • Take note to not lose the washer that sits on top of the armature.
  6. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 6 中的图像 1,2 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 6 中的图像 2,2
    • Remove the black insulator ring.
    • Remove the two 45mm Torx T15 screws securing the field to the drill.
  7. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 7 中的图像 1,3 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 7 中的图像 2,3 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 7 中的图像 3,3
    • Position drill on its side.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screws.
    • Remove the top portion of the handle.
  8. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 8 中的图像 1,2 Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 8 中的图像 2,2
    • Lift the switch up and away to allow room to work.
    • Uncrimp the wire connector on the yellow field wire attached to the switch to disconnect it.
  9. Milwaukee Hole Hawg 1675-1 Field Replacement: 步骤 9 中的图像 1,1
    • Lift the field out of the device, feeding the yellow wire through the handle.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 619
