简介
Use this guide to help you replace the reverse button in your Milwaukee Hex Impact Driver 2753-20. If your reverse button is either stuck or unresponsive, it likely needs to be replaced. This guide will show you where to locate the switch and how to safely remove it.
你所需要的
Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
Remove the two 40 mm Torx T10 screws near the bottom of the cover.
Locate the black forward/reverse button underneath the chuck.
Pull the button gently towards you to remove it from the trigger assembly.
