跳转到主内容
Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement
你所需要的
  1. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: 步骤 2 中的图像 1,1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: 步骤 3 中的图像 1,3 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: 步骤 3 中的图像 2,3 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: 步骤 3 中的图像 3,3
    • Pulling directly outward, remove the driver head from the motor assembly by picking it up out of the casing.
  4. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: 步骤 4 中的图像 1,1
    • Remove the drive shaft assembly from the motor coils.
    • There will be resistance when removing the drive shaft as there is magnetism working against you.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 760
