跳转到主内容
Milwaukee Hex Impact Driver 2750-20 Output Shaft Bearing Replacement
你所需要的
  1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 2 中的图像 1,1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Output Shaft Bearing: 步骤 3 中的图像 1,1
    • Once the interior is open locate the output shaft driver pictured at the left of the screen.
  4. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 4 中的图像 1,3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 4 中的图像 2,3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 4 中的图像 3,3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
  5. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 5 中的图像 1,3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 5 中的图像 2,3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the fan and the drive shaft assembly from the motor core assembly.
    • Using a pair of tweezers, remove the retaining ring.
    • Remove the old bearing and reinstall the new retaining clip.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 14
总计 602
