跳转到主内容
Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement
你所需要的
  1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: 步骤 1 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: 步骤 1 中的图像 2,2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 步骤 2 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 步骤 2 中的图像 2,2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Forward/Reverse Switch: 步骤 3 中的图像 1,1
    • Gently move the trigger assembly out of the way and remove the switch from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 1,701
