跳转到主内容
Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement
你所需要的
  1. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Battery: 步骤 1 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Battery: 步骤 1 中的图像 2,2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 步骤 2 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 步骤 2 中的图像 2,2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Electric Motor: 步骤 3 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Electric Motor: 步骤 3 中的图像 2,2
    • Remove the two 6mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
  4. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 步骤 4 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the gear case and electric motor assembly from the impact driver case by pulling up on it.
  5. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 步骤 5 中的图像 1,1
    • The gear case is easily separated from the electric motor by gently pulling the two pieces apart.
  6. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 步骤 6 中的图像 1,2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 步骤 6 中的图像 2,2
    • Insert the opening pick between one of the carbon brushes and the electric motor to help compress the spring.
    • While compressing the spring slide that section of the brush block assembly over the bearing.
    • The brush block assembly should easily slide over the bearing now , if it does not repeat the above process as needed for the other three carbon brushes.
    • When you remove the brush block assembly, the remaining component is the electric motor.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 1,413
