跳转到主内容
Milwaukee Hackzall 2625-20 Gearbox Replacement
你所需要的
  1. Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: 步骤 1 中的图像 1,2 Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Gearbox Replacement, Gearbox: 步骤 2 中的图像 1,1
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws.
    • Pull out the shoe and gearbox to remove the screw on the other side
  3. Milwaukee Hackzall 2625-20 Gearbox Replacement: 步骤 3 中的图像 1,3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 步骤 3 中的图像 2,3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 步骤 3 中的图像 3,3
    • Using your finger, push the rubber band up then slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Gearbox Replacement: 步骤 4 中的图像 1,3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 步骤 4 中的图像 2,3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 步骤 4 中的图像 3,3
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. You will use a T15 Torx screwdriver to remove 14.0 mm screws.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 25
总计 1,918
