跳转到主内容
Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement
你所需要的
  1. Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement: 步骤 2 中的图像 1,3 Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement: 步骤 2 中的图像 2,3 Milwaukee Circular Saw 263020 B57A 2008 Back Panel Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 58
