跳转到主内容
Milwaukee 5262-21 Reduction Gear Assembly Replacement
你所需要的
  1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Housing Assembly: 步骤 1 中的图像 1,1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: 步骤 3 中的图像 1,2 Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: 步骤 3 中的图像 2,2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 4 中的图像 1,2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 5 中的图像 1,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 5 中的图像 2,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 5 中的图像 3,3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 6 中的图像 1,2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 6 中的图像 2,2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 7 中的图像 1,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 7 中的图像 2,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 7 中的图像 3,3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 8 中的图像 1,2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 8 中的图像 2,2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 9 中的图像 1,2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 9 中的图像 2,2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 10 中的图像 1,2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 10 中的图像 2,2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 11 中的图像 1,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 11 中的图像 2,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 11 中的图像 3,3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 12 中的图像 1,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 12 中的图像 2,3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 步骤 12 中的图像 3,3
    • Now pull the reduction gear assembly up and out of the diaphragm.
结论
另外一个人完成了本指南。
Payton Parker
于03/08/19注册
534 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 22
总计 1,346
