跳转到主内容
Milwaukee 5262-21 Power Cord Replacement
你所需要的
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: 步骤 1 中的图像 1,1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: 步骤 3 中的图像 1,2 Milwaukee 5262-21 Power Cord Replacement, Power Cord: 步骤 3 中的图像 2,2
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: 步骤 4 中的图像 1,3 Milwaukee 5262-21 Power Cord Replacement: 步骤 4 中的图像 2,3 Milwaukee 5262-21 Power Cord Replacement: 步骤 4 中的图像 3,3
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: 步骤 5 中的图像 1,3 Milwaukee 5262-21 Power Cord Replacement: 步骤 5 中的图像 2,3 Milwaukee 5262-21 Power Cord Replacement: 步骤 5 中的图像 3,3
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
结论
Adrien Andrade-Cain
于03/08/19注册
181 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 314
