跳转到主内容
Milwaukee 5262-21 Motor Housing Replacement
你所需要的
  1. Milwaukee 5262-21 Motor Housing Replacement, Housing Assembly: 步骤 1 中的图像 1,1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Motor Housing Replacement: 步骤 2 中的图像 1,1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: 步骤 3 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: 步骤 3 中的图像 2,2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Motor Housing Replacement: 步骤 4 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 4 中的图像 2,2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Motor Housing Replacement: 步骤 5 中的图像 1,3 Milwaukee 5262-21 Motor Housing Replacement: 步骤 5 中的图像 2,3 Milwaukee 5262-21 Motor Housing Replacement: 步骤 5 中的图像 3,3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Motor Housing Replacement: 步骤 6 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 6 中的图像 2,2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Motor Housing Replacement: 步骤 7 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 7 中的图像 2,2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Motor Housing Replacement: 步骤 8 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 8 中的图像 2,2
    • Remove the fan baffle by pulling it out.
  9. Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: 步骤 9 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: 步骤 9 中的图像 2,2
    • Pull the black wire(shown in the image) out of the trigger assembly.
  10. Milwaukee 5262-21 Motor Housing Replacement: 步骤 10 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 10 中的图像 2,2
    • Pull the white wire (shown in the image) out of the trigger assembly.
  11. Milwaukee 5262-21 Motor Housing Replacement: 步骤 11 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 11 中的图像 2,2
    • Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
  12. Milwaukee 5262-21 Motor Housing Replacement: 步骤 12 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 12 中的图像 2,2
    • Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
  13. Milwaukee 5262-21 Motor Housing Replacement: 步骤 13 中的图像 1,3 Milwaukee 5262-21 Motor Housing Replacement: 步骤 13 中的图像 2,3 Milwaukee 5262-21 Motor Housing Replacement: 步骤 13 中的图像 3,3
    • After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
    • You may need to use a screwdriver to push the assembly from behind.
  14. Milwaukee 5262-21 Motor Housing Replacement: 步骤 14 中的图像 1,3 Milwaukee 5262-21 Motor Housing Replacement: 步骤 14 中的图像 2,3 Milwaukee 5262-21 Motor Housing Replacement: 步骤 14 中的图像 3,3
    • Once the assembly is loose, pull each half out of the housing.
    • Note the orientation of how the halves sit together in the housing before removal.
  15. Milwaukee 5262-21 Motor Housing Replacement: 步骤 15 中的图像 1,2 Milwaukee 5262-21 Motor Housing Replacement: 步骤 15 中的图像 2,2
    • Remove the motor housing from the device.
结论
Andrew Floyd
于03/08/19注册
277 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 6
总计 281
