跳转到主内容
Milwaukee 2780-20 Trigger Assembly Replacement
你所需要的
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: 步骤 1 中的图像 1,3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: 步骤 1 中的图像 2,3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: 步骤 1 中的图像 3,3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 2 中的图像 1,3 Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 2 中的图像 2,3 Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 2 中的图像 3,3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 3 中的图像 1,1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 4 中的图像 1,3 Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 4 中的图像 2,3 Milwaukee 2780-20 Trigger Assembly Replacement: 步骤 4 中的图像 3,3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 27
总计 1,189
