跳转到主内容
Milwaukee 2780-20 Rotor Assembly Replacement
你所需要的
  1. Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: 步骤 1 中的图像 1,3 Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: 步骤 1 中的图像 2,3 Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: 步骤 1 中的图像 3,3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 2 中的图像 1,3 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 2 中的图像 2,3 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 2 中的图像 3,3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 3 中的图像 1,1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 4 中的图像 1,3 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 4 中的图像 2,3 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 4 中的图像 3,3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: 步骤 5 中的图像 1,3 Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: 步骤 5 中的图像 2,3 Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: 步骤 5 中的图像 3,3
    • Using a Torx T20 screwdriver, unscrew the four 6mm screws located at the top of the gearcase assembly.
    • Pull apart the top of the gearcase assembly to expose the inside of it.
  6. Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 6 中的图像 1,2 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 6 中的图像 2,2
    • Pull the Gearcase Assembly away from the electronic kit.
  7. Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 7 中的图像 1,2 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 7 中的图像 2,2
    • Using a 3/8 wrench, remove the nut located in the center of the Gearcase.
    • The nut and pinion will immediately come apart from the Rotor assembly.
  8. Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 8 中的图像 1,3 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 8 中的图像 2,3 Milwaukee 2780-20 Rotor Assembly Replacement: 步骤 8 中的图像 3,3
    • Pull the rotor assembly away from the gearcase assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 12
总计 902
