跳转到主内容
Milwaukee 2780-20 (2) Ball Bearings Replacement
你所需要的
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 步骤 1 中的图像 1,3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 步骤 1 中的图像 2,3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 步骤 1 中的图像 3,3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 2 中的图像 1,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 2 中的图像 2,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 2 中的图像 3,3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 3 中的图像 1,1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 4 中的图像 1,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 4 中的图像 2,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 4 中的图像 3,3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 步骤 5 中的图像 1,3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 步骤 5 中的图像 2,3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 步骤 5 中的图像 3,3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 6 中的图像 1,2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 6 中的图像 2,2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 7 中的图像 1,2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 7 中的图像 2,2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 8 中的图像 1,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 8 中的图像 2,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 8 中的图像 3,3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 9 中的图像 1,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 9 中的图像 2,3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 9 中的图像 3,3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 10 中的图像 1,2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 步骤 10 中的图像 2,2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 41
总计 2,999
