跳转到主内容
Midland X-tra Talk Radio LXT118 Speaker Replacement
你所需要的
  1. Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: 步骤 1 中的图像 1,2 Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: 步骤 1 中的图像 2,2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Speaker Replacement: 步骤 2 中的图像 1,1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Speaker Replacement, Case: 步骤 3 中的图像 1,1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Speaker Replacement: 步骤 4 中的图像 1,1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Midland X-tra Talk Radio LXT118 Speaker Replacement: 步骤 6 中的图像 1,1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Midland X-tra Talk Radio LXT118 Speaker Replacement: 步骤 7 中的图像 1,1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Midland X-tra Talk Radio LXT118 Speaker Replacement: 步骤 8 中的图像 1,1
    • The speaker is now disassembled!
  9. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: 步骤 9 中的图像 1,1
    • Solder the new wires to the circuit board in the spots denoted by the two red circles.
  10. Midland X-tra Talk Radio LXT118 Speaker Replacement: 步骤 10 中的图像 1,1
    • Place the speaker back inside the shell casing in the same way that it was originally placed.
    • Accurately use a polyurethane glue around the rim of the speaker to mount it firmly back inside the plastic casing.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G43
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 760
