跳转到主内容
Midland X-tra Talk Radio LXT118 Antenna Replacement
你所需要的
  1. Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: 步骤 1 中的图像 1,2 Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: 步骤 1 中的图像 2,2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Antenna Replacement: 步骤 2 中的图像 1,1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Antenna Replacement, Case: 步骤 3 中的图像 1,1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Antenna Replacement: 步骤 4 中的图像 1,1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Antenna Replacement, Antenna: 步骤 5 中的图像 1,1
    • Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
  6. Midland X-tra Talk Radio LXT118 Antenna Replacement: 步骤 6 中的图像 1,1
    • Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
    • Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
    • Desolder the connection of the antenna to the motherboard. Careful!, if used improperly, the soldering tool can damage the circuit board!
  7. Midland X-tra Talk Radio LXT118 Antenna Replacement: 步骤 7 中的图像 1,1
    • After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
结论
5等其他人完成本指南。
Andre Nguyen
于01/18/13注册
108 声望
撰写一个指南
团队
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G43
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 2,093
