跳转到主内容
Midiman Oxygen 8 Backplate Disassembly
你所需要的
  1. Midiman Oxygen 8 Backplate Disassembly, Midiman Oxygen 8 Backplate Disassembly: 步骤 1 中的图像 1,2 Midiman Oxygen 8 Backplate Disassembly, Midiman Oxygen 8 Backplate Disassembly: 步骤 1 中的图像 2,2
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
  2. Midiman Oxygen 8 Backplate Disassembly: 步骤 2 中的图像 1,2 Midiman Oxygen 8 Backplate Disassembly: 步骤 2 中的图像 2,2
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
  3. Midiman Oxygen 8 Backplate Disassembly: 步骤 3 中的图像 1,3 Midiman Oxygen 8 Backplate Disassembly: 步骤 3 中的图像 2,3 Midiman Oxygen 8 Backplate Disassembly: 步骤 3 中的图像 3,3
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
  4. Midiman Oxygen 8 Backplate Disassembly: 步骤 4 中的图像 1,2 Midiman Oxygen 8 Backplate Disassembly: 步骤 4 中的图像 2,2
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
结论
Alexander Heitzman
于10/05/16注册
101 声望
撰写一个指南
团队
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S1G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 356
