跳转到主内容
Midea MRU03M2ABB Upright Freezer Door Replacement
你所需要的
  1. Midea MRU03M2ABB Upright Freezer Door Replacement, Door: 步骤 1 中的图像 1,2 Midea MRU03M2ABB Upright Freezer Door Replacement, Door: 步骤 1 中的图像 2,2
    • Unplug the device.
    • Only unplug when your hand is dry.
  2. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 2 中的图像 1,1
    • Empty the shelves.
  3. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 3 中的图像 1,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 3 中的图像 2,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 3 中的图像 3,3
    • Use a plastic spatula to remove the hinge cover on top of the freezer.
    • Pushing at the pointy part of the cover makes it easier to remove.
  4. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 4 中的图像 1,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 4 中的图像 2,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 4 中的图像 3,3
    • Unscrew the hinge counterclockwise.
  5. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 5 中的图像 1,2 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 5 中的图像 2,2
    • Lift the hinge out of the freezer and the door.
  6. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 6 中的图像 1,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 6 中的图像 2,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 6 中的图像 3,3
    • With two hands, gently hold and open the door as usual.
    • Lift the door up to remove it from the bottom hinge.
    • You have completely detached the door from the freezer.
  7. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 7 中的图像 1,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 7 中的图像 2,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 7 中的图像 3,3
    • With the new door, locate the hole underneath the door.
    • Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
    • Close the door.
  8. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 8 中的图像 1,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 8 中的图像 2,3 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 8 中的图像 3,3
    • Use your hand to align the door so these three screw holes stay on the same line.
    • Carefully place the top hinge to fit these holes.
  9. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 9 中的图像 1,2 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 9 中的图像 2,2
    • Thread and tighten the screws clockwise.
    • Gently swing the door to make sure it operates well.
  10. Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 11 中的图像 1,2 Midea MRU03M2ABB Upright Freezer Door Replacement: 步骤 11 中的图像 2,2
    • Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
    • A "click" will indicate that the cover is finally in its place.
终点
Thinh Lang
于01/16/24注册
193 声望
撰写一个指南
1指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 49
总计 923
