跳转到主内容
Midas Pro 2C CMOS Battery Replacement
你所需要的
  1. Midas Pro 2C CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 1,1
    • Turn the Midas Pro 2C off and ensure your work area is clear.
  2. Midas Pro 2C CMOS Battery Replacement: 步骤 2 中的图像 1,2 Midas Pro 2C CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the switches connected to the two power supply units (PSU) to the off position.
  3. Midas Pro 2C CMOS Battery Replacement: 步骤 3 中的图像 1,2 Midas Pro 2C CMOS Battery Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the cords from both PSU’s.
  4. Midas Pro 2C CMOS Battery Replacement: 步骤 4 中的图像 1,2 Midas Pro 2C CMOS Battery Replacement: 步骤 4 中的图像 2,2
    • Flip both PSU switches back to the on position.
    • Leave the PSUs on for 30 seconds to ensure that the power is fully discharged from the units.
  5. Midas Pro 2C CMOS Battery Replacement: 步骤 5 中的图像 1,2 Midas Pro 2C CMOS Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the twelve 10 mm T10 Torx screws from the cover of the console.
  6. Midas Pro 2C CMOS Battery Replacement: 步骤 6 中的图像 1,2 Midas Pro 2C CMOS Battery Replacement: 步骤 6 中的图像 2,2
    • Set a cloth down over the top half of the console to protect it from damage in the following steps.
  7. Midas Pro 2C CMOS Battery Replacement: 步骤 7 中的图像 1,3 Midas Pro 2C CMOS Battery Replacement: 步骤 7 中的图像 2,3 Midas Pro 2C CMOS Battery Replacement: 步骤 7 中的图像 3,3
    • Use a metal spudger to carefully pry the control panel from the console.
    • Work your way around the perimeter with the spudger to undo the clips securing the control panel and remove it from the console.
    • Keep your hand in constant contact with the panel, dropping it may damage the unit.
    • Lift the panel very slowly and ensure none of the fader's cables get stuck on the inside edge of the console.
  8. Midas Pro 2C CMOS Battery Replacement: 步骤 8 中的图像 1,3 Midas Pro 2C CMOS Battery Replacement: 步骤 8 中的图像 2,3 Midas Pro 2C CMOS Battery Replacement: 步骤 8 中的图像 3,3
    • Disconnect the ribbon cable from the control panel by moving the two black latches outward, away from the cable.
    • Pull out the cable.
    • Lay the panel against the material you used to cover the top section of board but make sure panel doesn't slide or fall.
  9. Midas Pro 2C CMOS Battery Replacement: 步骤 9 中的图像 1,3 Midas Pro 2C CMOS Battery Replacement: 步骤 9 中的图像 2,3 Midas Pro 2C CMOS Battery Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Identify the CMOS battery to the right of the circuit board.
    • To remove the battery, push the metal tab out of the way, and use the tweezers to pull out the old battery.
    • Check with your local battery recycling guidelines to discard the old battery.
  10. Midas Pro 2C CMOS Battery Replacement: 步骤 10 中的图像 1,2 Midas Pro 2C CMOS Battery Replacement: 步骤 10 中的图像 2,2
    • To insert the new 2032 battery, push the tab back and slide in the new battery.
    • Make sure the new battery is oriented the same way as the old battery.
  11. Midas Pro 2C CMOS Battery Replacement: 步骤 11 中的图像 1,3 Midas Pro 2C CMOS Battery Replacement: 步骤 11 中的图像 2,3 Midas Pro 2C CMOS Battery Replacement: 步骤 11 中的图像 3,3
    • Reattach the ribbon cable to the control panel.
    • Secure the locking latches by pushing them towards the cable.
    • Carefully lower the panel back onto the console, make sure the wires aren’t being pinched as you set the panel back down.
    • Replace the screws to attach the control panel to the the console.
  12. Midas Pro 2C CMOS Battery Replacement: 步骤 12 中的图像 1,3 Midas Pro 2C CMOS Battery Replacement: 步骤 12 中的图像 2,3 Midas Pro 2C CMOS Battery Replacement: 步骤 12 中的图像 3,3
    • Make sure both PSUs are off, then plug the UPC cables back in.
    • Turn both the PSU units on, this should switch the console on.
    • As the console turns on and boots up, press F2 frequently until the console enters into the set-up menu.
  13. Midas Pro 2C CMOS Battery Replacement: 步骤 13 中的图像 1,1
    • Read directions on the console to navigate through the set up menu.
    • Change the date and time they are correct.
  14. Midas Pro 2C CMOS Battery Replacement: 步骤 14 中的图像 1,3 Midas Pro 2C CMOS Battery Replacement: 步骤 14 中的图像 2,3 Midas Pro 2C CMOS Battery Replacement: 步骤 14 中的图像 3,3
    • Click down with arrow key to the "excluded from boot order list".
    • Press the X key while “ATP Compact Flash” is highlighted in white.
    • This adds the operating system back to the order.
    • Navigate to the exit.
    • Arrow key down to save and exit.
    • Confirm changes by selecting yes.
  15. Midas Pro 2C CMOS Battery Replacement: 步骤 15 中的图像 1,1
    • The console should reboot back into the operating system.
    • Ensure the console date and time is set correctly and if not repeat steps 12 through 14.
结论
5等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 146
总计 6,492
