跳转到主内容
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
你所需要的
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 步骤 1 中的图像 1,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 步骤 1 中的图像 2,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 步骤 1 中的图像 3,3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 步骤 2 中的图像 1,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 步骤 2 中的图像 2,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 步骤 2 中的图像 3,3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 步骤 3 中的图像 1,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 步骤 3 中的图像 2,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 步骤 4 中的图像 1,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 步骤 4 中的图像 2,3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 步骤 4 中的图像 3,3
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: 步骤 5 中的图像 1,2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: 步骤 5 中的图像 2,2
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
结论
Taylor Nesheim
于10/11/11注册
59 声望
创作了7篇指南
团队
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G9
2 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,259
