跳转到主内容
Microtek ScanMaker 5900 New Bulb Replacement
你所需要的
  1. Microtek ScanMaker 5900 New Bulb Replacement, Remove serial port connection: 步骤 1 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Remove serial port connection: 步骤 1 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Remove serial port connection: 步骤 1 中的图像 3,3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Bulb Replacement, Remove Lid: 步骤 2 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Remove Lid: 步骤 2 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Remove Lid: 步骤 2 中的图像 3,3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Bulb Replacement, Detach plastic latches: 步骤 3 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Detach plastic latches: 步骤 3 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Detach plastic latches: 步骤 3 中的图像 3,3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 New Bulb Replacement, Continue latch detachment: 步骤 4 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Continue latch detachment: 步骤 4 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Continue latch detachment: 步骤 4 中的图像 3,3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 New Bulb Replacement, Fully remove the upper lid: 步骤 5 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Fully remove the upper lid: 步骤 5 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Fully remove the upper lid: 步骤 5 中的图像 3,3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 New Bulb Replacement, Locate the bulb: 步骤 6 中的图像 1,2 Microtek ScanMaker 5900 New Bulb Replacement, Locate the bulb: 步骤 6 中的图像 2,2
    • After opening the chassis, you will see a white bulb spanning the width of the scanner.
    • Lift up the black piece of plastic the bulb is attached to from the left hand side until it is perpendicular with the bottom lid of the scanner.
  7. Microtek ScanMaker 5900 New Bulb Replacement, Detach the bulb electrical connection: 步骤 7 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Detach the bulb electrical connection: 步骤 7 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Detach the bulb electrical connection: 步骤 7 中的图像 3,3
    • Use tweezers to grab the plastic casing the wires are housed in.
    • Gently jiggle the plastic back and forth until it can be pulled from its connection.
    • Pull the wires out of the circuit board.
    • Pull the wires up and out over the top of the plastic housing.
  8. Microtek ScanMaker 5900 New Bulb Replacement, Remove the bulb: 步骤 8 中的图像 1,3 Microtek ScanMaker 5900 New Bulb Replacement, Remove the bulb: 步骤 8 中的图像 2,3 Microtek ScanMaker 5900 New Bulb Replacement, Remove the bulb: 步骤 8 中的图像 3,3
    • Place the plastic housing back into the bottom lid of the scanner.
    • Remove the plastic panel by gently pushing on the plastic latches with a plastic opening tool.
    • Pull the bulb and wire out of its plastic casing.
    • The bulb is now free to be replaced.
结论
Taylor Nesheim
于10/11/11注册
59 声望
创作了7篇指南
团队
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G9
2 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,652
