当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
Slightly rotate the top edge of the upper rear panel away from the Zune.
Lift the upper rear panel straight up off the black plastic lower rear panel.
Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
Repeat this process for the other side of the lower rear panel.
Carefully slide the lower rear panel away from the Zune.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
694,785 声望
创作了1,203篇指南
徽章: 54
+ 51更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 3,131
