跳转到主内容
Microsoft Zune HD Lower Rear Panel Replacement
你所需要的
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: 步骤 1 中的图像 1,1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: 步骤 2 中的图像 1,2 Microsoft Zune HD Lower Rear Panel Replacement: 步骤 2 中的图像 2,2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: 步骤 3 中的图像 1,2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: 步骤 3 中的图像 2,2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: 步骤 4 中的图像 1,1
    • Carefully slide the lower rear panel away from the Zune.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,114
