跳转到主内容
Microsoft Zune HD Inner Chassis Replacement
你所需要的
  1. Microsoft Zune HD Inner Chassis Replacement, Upper Rear Panel: 步骤 1 中的图像 1,1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Inner Chassis Replacement: 步骤 2 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement: 步骤 2 中的图像 2,2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Inner Chassis Replacement, Lower Rear Panel: 步骤 3 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement, Lower Rear Panel: 步骤 3 中的图像 2,2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Inner Chassis Replacement: 步骤 4 中的图像 1,1
    • Carefully slide the lower rear panel away from the Zune.
  5. Microsoft Zune HD Inner Chassis Replacement, Battery & Logic Board: 步骤 5 中的图像 1,1
    • Use a Zune opening tool to pry the digitizer ribbon cable connector up off the logic board.
  6. Microsoft Zune HD Inner Chassis Replacement: 步骤 6 中的图像 1,1
    • Use a Zune opening tool to pry the OLED display ribbon cable connector up off the logic board.
  7. Microsoft Zune HD Inner Chassis Replacement: 步骤 7 中的图像 1,1
    • Use a Zune opening tool to pry the control ribbon cable up off the logic board.
  8. Microsoft Zune HD Inner Chassis Replacement: 步骤 8 中的图像 1,1
    • Remove the following Torx screws securing the logic board assembly to the inner chassis:
    • Three T5 Torx screws.
    • One T6 Torx screw.
  9. Microsoft Zune HD Inner Chassis Replacement: 步骤 9 中的图像 1,1
    • Use a Zune opening tool to carefully pry the battery off the adhesive securing it to the inner chassis.
    • Do not attempt to completely remove the battery from the inner chassis as it is still attached to the the logic board.
  10. Microsoft Zune HD Inner Chassis Replacement: 步骤 10 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement: 步骤 10 中的图像 2,2
    • Use a Zune opening tool to push the small plastic clip securing the logic board near its lower left edge toward the headphone jack while gently lifting the upper edge of the logic board.
    • Use a Zune opening tool to pull the plastic clip away from the logic board while gently pulling the board away from the bottom edge of the Zune.
  11. Microsoft Zune HD Inner Chassis Replacement: 步骤 11 中的图像 1,1
    • For this step, it is recommended to cautiously hold the battery and logic board assembly with one hand while holding the inner chassis with the other.
    • Pull the logic board away from the lower bezel and remove it from the inner chassis, minding any cables that may get caught.
  12. Microsoft Zune HD Inner Chassis Replacement, Inner Chassis: 步骤 12 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement, Inner Chassis: 步骤 12 中的图像 2,2
    • Insert the edge of a Zune opening tool between the black lower bezel and the front case.
    • Pry the lower bezel up off the front case and set it aside.
  13. Microsoft Zune HD Inner Chassis Replacement: 步骤 13 中的图像 1,1
    • Lift the upper bezel off the front case.
  14. Microsoft Zune HD Inner Chassis Replacement: 步骤 14 中的图像 1,1
    • Remove the single T5 Torx screw securing the front case to the inner chassis.
  15. Microsoft Zune HD Inner Chassis Replacement: 步骤 15 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement: 步骤 15 中的图像 2,2
    • Use a Zune opening tool to peel the digitizer and display ribbon cables off the foam tape securing them to the inner chassis.
  16. Microsoft Zune HD Inner Chassis Replacement: 步骤 16 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement: 步骤 16 中的图像 2,2
    • Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
    • Try not excessively rotate the media button lever about this post.
  17. Microsoft Zune HD Inner Chassis Replacement: 步骤 17 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement: 步骤 17 中的图像 2,2
    • The inner chassis attaches to the front case by several clips around its perimeter (shown in red). The clips emanating from the front case are plastic and inherently delicate, so work carefully.
    • The five plastic clips along the side of the Zune lock onto small aluminum tabs cast into the inner chassis. To separate these clips, the plastic portion must be pushed toward the inside of the Zune while prying the inner chassis up off the front case.
    • The two plastic clips attached to the front case along the top edge of the Zune (second picture) simply clip onto the inner chassis. To separate the top edge, carefully push each clip away from the inside of the Zune while prying the inner chassis off the front case.
  18. Microsoft Zune HD Inner Chassis Replacement: 步骤 18 中的图像 1,2 Microsoft Zune HD Inner Chassis Replacement: 步骤 18 中的图像 2,2
    • This job can be completed alone, but we used a second set of hands for picture taking purposes.
    • Use a Zune opening tool to gently pry the inner chassis off the front case while simultaneously using another Zune opening tool to push the plastic clip near the control cable connector toward the inside of the Zune.
    • Work your way along the media button side of the Zune to separate both clips securing the front case to the inner chassis.
  19. Microsoft Zune HD Inner Chassis Replacement: 步骤 19 中的图像 1,1
    • Use a Zune opening tool to very carefully bend both plastic clips along the top edge of the Zune away from the inner chassis while simultaneously prying the respective side of the inner chassis up off the front case.
    • Once the top edge of the inner chassis has been released from the front case, separate the clips along the right edge of the Zune.
    • Lift the inner chassis off the front case, minding the digitizer and display ribbon cables routed through a slot near its center.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,829
