跳转到主内容
简介
Removal and replacement of Hard Drive.
配件
没有特定配件。
  1. Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. There are two T4 screws under the cap. Remove both with a T4 screwdriver.
    • There are two T4 screws under the cap. Remove both with a T4 screwdriver.
    • Be careful removing the screws; the screw heads can break very easily.
  3. Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
  4. Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery. Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
    • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
  5. Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive. If the cable doesn't come off easily, the black bar has not been un-clicked. Now gently pull the orange hard drive cable to remove it from the hard drive.
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
    • If the cable doesn't come off easily, the black bar has not been un-clicked.
    • Now gently pull the orange hard drive cable to remove it from the hard drive.
    • Lift the hard drive from the device.
    • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
结论
7等其他人完成本指南。
turey
于2009年11月11日注册
333 信誉积分
创作了2篇指南
团队
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 20
总计 11,052
