跳转到主内容
加入维修社区 - 创建账户
Microsoft Zune 80 Hard Drive Replacement
你所需要的
    1. Microsoft Zune 80 Hard Drive Replacement, Case: 步骤 1 中的图像 1,1
      • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
      询问修复机器人
      添加评论
    2. Microsoft Zune 80 Hard Drive Replacement: 步骤 2 中的图像 1,1
      • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
      • Be careful with removing these screws! These screwheads are prone to breaking.
      添加评论
    3. Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: 步骤 3 中的图像 1,2 Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: 步骤 3 中的图像 2,2
      • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
      • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
      询问修复机器人
      添加评论
    1. Microsoft Zune 80 Hard Drive Replacement, Remove the Silver Tape: 步骤 4 中的图像 1,2 Microsoft Zune 80 Hard Drive Replacement, Remove the Silver Tape: 步骤 4 中的图像 2,2
      • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
      询问修复机器人
      添加评论
    2. Microsoft Zune 80 Hard Drive Replacement: 步骤 5 中的图像 1,3 Microsoft Zune 80 Hard Drive Replacement: 步骤 5 中的图像 2,3 Microsoft Zune 80 Hard Drive Replacement: 步骤 5 中的图像 3,3
      • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
      • If the cable doesn't come off easily, the black bar has not been un-clicked.
      • The hard drive cable (ZIF cable) is very fragile. Try to keep it in its original shape and bend it as little as possible.
      • Now gently pull the orange hard drive cable to remove it from the hard drive.
      • Lift the hard drive from the device.
      • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
turey
于11/11/09注册
417 声望
创作了2篇指南
团队
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G5
5 名成员
创作了18篇指南
1指南评论
what model hard drive did you utilize during its replacement?
thanksss
RAFI V DEMIRJIAN - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 60
总计 14,334
