简介
These instructions show the removal of the Zune 80GB back casing. Removal of this component allows access to the internal components of the Zune 80GB.
你所需要的
There are two T3 screws under the cap. Remove both with a T3 screwdriver.
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
即将完成!
结论
另外一个人完成了本指南。
